| Vedeni ventilu https://mitsubishi.megaherz.cz/viewtopic.php?f=50&t=2526 |
| Autor: | expresion [ 12 únor 2013 16:33 ] |
| Předmět příspěvku: | Vedeni ventilu |
Mam dotaz, jsem nejaky zmateny, jake presne voditka ventilu potrebuju do sveho Stealth 91 FWD? Na 3SX pisou toto: NOTE: Sizes on 3000GT/Stealth AWD: According to Mitsubishi, the AWD rear is a 10mm valve if your build date is April 90 - Feb 92, then Mar 92 - May 93 uses a 7mm valve, then June 93+ (i.e., 94 model and later) are back to the 10mm valve. For the AWD front caliper, they use the 10mm for all years. We still recommend you check your valve sizes prior to ordering. NOTE: Sizes on 3000GT/Stealth FWD: According to Mitsubishi, the FWD front AND rear calipers use a 10mm valve April 90 - Feb 92, then the 7mm valve March 92 and later. We still recommend you check your valve sizes prior to ordering. NOTE: Sizes on Starion/Conquest - The StarQuests use 10mm for both front and rear calipers. http://www.3sx.com/store/comersus_viewI ... oduct=1415 Ja mam mit "caliber" 10mm podle toho co pisou, nevite kde sezenu takove voditka? |
| Autor: | Mitsi [ 12 únor 2013 18:41 ] |
| Předmět příspěvku: | Re: Vedeni ventilu |
expresion píše: Mam dotaz, jsem nejaky zmateny, jake presne voditka ventilu potrebuju do sveho Stealth 91 FWD? Na 3SX pisou toto: ... For the AWD front caliper, they use the 10mm for all years. We still recommend you check your valve sizes prior to ordering. ... NOTE: Sizes on Starion/Conquest - The StarQuests use 10mm for both front and rear calipers. http://www.3sx.com/store/comersus_viewI ... oduct=1415 Ja mam mit "caliber" 10mm podle toho co pisou, nevite kde sezenu takove voditka? Rozlišuješ vůbec mezi "vodítky ventilů" a odvzdušňováky na brzdových třmenech (to jsou ty calipers - s "kalibrem" to nemá vůbec nic společného)? Viděl jsi v reálu na vlastní oči alespoň jedno z toho? |
| Autor: | Brumla [ 12 únor 2013 20:02 ] |
Ahoj, potřebuješ toto: http://evilempireperformance.co.uk/gto-3000gt-shop/index.php?main_page=product_info&cPath=30_165_166&products_id=339 a http://evilempireperformance.co.uk/gto-3000gt-shop/index.php?main_page=product_info&cPath=30_165_166&products_id=338 v čechách koupíš zde: http://www.eliteauto.cz/ventily-voditka-dily/Mitsubishi_3000-gt-z16a/vedeni-ventilu-o95058/ a zde http://www.eliteauto.cz/ventily-voditka-dily/Mitsubishi_3000-gt-z16a/vedeni-ventilu-o95059/ mnoho zdaru! |
| Autor: | expresion [ 12 únor 2013 20:37 ] |
Dikes Brumlo! Uz jdu na to to objednat...tedy od kazdeho 12ks spravne? |
| Autor: | Brumla [ 12 únor 2013 20:42 ] |
ano...... |
